Solved [Flow] Target endpoint for xxxxxx3332 can not be built!
AlanGrnja
Just setup default 3cx PBX on google cloud. All default settings. Trying to make outbound calls, this is error to any and all phone numbers i dial. I am using web client.
Looks no you do not have any OUTBOUND RULES.
Setup a VOIP Provider first?
Reactions: JCLloyd
I setup SIP TRUNK
do i need to actually setup outbound rules , or will it work with blank settings?
Reactions: JCLloyd
I agree with Craig. I just had a similar issue, yesterday... I have a fax machine with the 9 prefix programmed into the speed dials, and I am now on direct dial with 3CX. Rather than edit all the speed dials in the fax machine, I added an outbound rule to strip out the leading digit, if it is a 9 and meets the added character length (8 or 12 instead of 7 or 11).
I hope that helps!
Reactions: craigreilly
You need some sort of rule that says to us a trunk route. Create one with at least this (assuming US):
- Calls to numbers with a length of: 7,10,11
- Calls from extension group: default
- Route 1: choose your SIP provider; replace the BLOCK CALLS
You may need to add a second route, if you have a failover or load balance IP from your provider.
Reactions: pcp192
ok i created outbound rule now error is Cause: 407 Proxy Authentication Required/INVITE from xxx.xxx.191.155:5060
Reactions: JCLloyd
Alan, it sounds like you are very new to setting things up... I don't mean to offend...
. Next week, there are a couple free online web events 3CX is offering that will guide you through the basics. I went through them, and they were very helpful... https://www.3cx.com/blog/event-trainings/
. The week after, there are three intermediate ones.
These are very informative, and the instructor I had was excellent. FYI
yes they were filled this week
thank you for the help in sip trunk settings under authentication, i had type of authentication - do not require that was correct . i just had to put user and password below and it works.
