- Joined
- Dec 13, 2022
- Messages
- 1
- Reaction score
- 0
Alright, so I have been working on this issue for the past 42 hours, and have kind of hit a roadblock, 3CX tells me this is a provider issue and Flowroute (the provider) is telling me this is a hardware issue. I have been going through the 3CX and Flowroute forums, Blogs, and Knowledgebases, and have found literally hundreds of posts that I have tried implementing the changes and non of them seem to do anything. The issue is I have 14 DID's with Flowroute,
my main DID is 0877, and the secondary DID's (used for Ad tracking) that redirect to the main number 0903 and 2199, as well as a toll free number 3104. I also have 10 Additional DID's for the various extensions ranging from 0020 - 0029.
The issue is the 0877 Number connects fine to the phone system (thankfully), all of the additional numbers do not, they return a proxy authentication required, I have already spoken with 3CX, who told me to add the + onto the front of the number (DID NOT WORK), spoke to flowroute that told me to only use a 1 at the front of a number as they only support 11 Digit redirection (DID NOT WORK), I have even found several posts speaking about adding the * instead of the + at the beginning of the number (DID NOT WORK). The authentication is setup as Register/Account Based, with my SIP User ID and Password, I have already changed my Transport protocol (per 3CX and Flowroutes recommendations) to UDP, I have enabled Supports Re-Invite and Supports Replaces (Per 3CX Recommendation). I have disabled Call Source Identification (Per Flowroute Tech Support) and changed all of the Caller Number/Name Field Mappings to "Leave Default Value" (Per Flowroute Tech).
Now I have run a Capture, and this is what I see:
So the kicker is that I have SMS on the Flowroute account as well, and that is working with 3CX, so I know that it is delivering to the server, but the server is kicking back the Proxy Authentication required, only on incoming phone calls.
I have even gone a step further and changed on of the secondary DID's to the Main Trunk number and voila, magically that number works and nothing else. Flowroute is adamant that this is a 3CX issue and 3CX seems to be saying the same thing. Some help would be greatly appreciated.
Code:
INVITE sip:*******@*******:5060 SIP/2.0
call-id: *******@*******
contact: <sip:+*******@*******5:5060>
content-length: 228
content-type: application/sdp
cseq: 111663 INVITE
from: "[V]SCOTT HENRY" <sip:+*******@fl.gg>;tag=gK0c6348b4
max-forwards: 66
min-se: 90
p-asserted-identity: "[V]SCOTT HENRY" <sip:+*******;[email protected]>
p-attestation-indicator: A
record-route: <sip:*******;lr>
session-expires: 21600
supported: timer
to: <sip:+*******@fl.gg>
via: SIP/2.0/UDP *******:5060;branch=z9hG4bKcfdb.46dcbde50a5ef045738cf85f05f3786b.0
v=0
o=- 975205 542535 IN IP4 *******
s=-
c=IN IP4 *******
t=0 0
m=audio 20462 RTP/AVP 0 8 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=maxptime:20
INVITE SIP/2.0
content-length: 0
cseq: 111663 INVITE
proxy-authenticate: Digest nonce="414d53596398b7f162:31f776428fd8447b4e7691c989e4e2f1",algorithm=MD5,realm="3CXPhoneSystem"
to: <sip:+*******@fl.gg>;tag=5a6acd5a
ACK sip:*******@*******:5060 SIP/2.0
content-length: 0
cseq: 111663 ACK
max-forwards: 66
