Flowroute - Do I have to add a DID to the trunk to receive calls to it?
coreybrett81
I am evaluating Flowroute and I have a trunk setup using the 3CX template.
It works and I can receive/make calls.
Right now I have 2 DIDs with Flowroute. I used one of them as the "Main Trunk No" when I created the trunk.
Calls to that number will complete as expected. However, calls to my other DID get rejected, unless I add it to the DID list.
The is the invite when the second DID is not added to the trunk.
Code:
05/12/2020 3:56:19 PM - [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Invite-UNK Recv Req INVITE from 147.75.65.192:5060 tid=c902.bf595251a9e8fda85e14b69eaa4f7efc.0 [email protected]:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 147.75.65.192;branch=z9hG4bKc902.bf595251a9e8fda85e14b69eaa4f7efc.0
Via: SIP/2.0/UDP 54.71.6.127:5060;branch=z9hG4bKc902.8bb924cee39199443bdc663d7f13139f.0
Via: SIP/2.0/UDP 35.173.62.45:5060;branch=z9hG4bKc902.222e9188a8185b29915cba7239b6bcb7.0
Via: SIP/2.0/UDP 23.29.25.86:5060;branch=z9hG4bK0bBaf1a1d7f9538ce29
Max-Forwards: 66
Record-Route: <sip:147.75.65.192;lr>
Record-Route: <sip:35.173.62.45;lr>
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
From: <sip:[email protected];isup-oli=00>;tag=gK0b623ec6
Call-ID: [email protected]
CSeq: 8545 INVITE
Session-Expires: 1800
Min-SE: 90
Content-Type: application/sdp
Supported: timer
P-Asserted-Identity: <sip:[email protected]>
Content-Length: 217
v=0
o=- 12106 6889 IN IP4 23.29.25.91
s=-
c=IN IP4 23.29.25.91
t=0 0
m=audio 23714 RTP/AVP 0 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=maxptime:20
If I only had a few DIDs this wouldn't be a big deal, but I have 200+. Most of which don't require inbound routing, but I need to catch any calls to them.
I have a trunk with another provider, and any calls to a DID that is not configuered on the truck, just get routed to the default destination, which is what I was expecting with the Flowroute truck.
Is there a way to fix this?
These are the default settings for Inbound Parameters...
Sounds like a good time to do a thorough evaluation of FlowRoute and see how their support is :)
Just import them from a csv.
And if they are similar, wildcards are allowed... minimum 4 digits.
ie: *480555* would match +14805551212, 4805551213, etc.
So I can use one row in the CSV to create the an entire block of DIDs by using a star?
it is a minimum of 4 digits - atleast when entering manually.
3K8iMGWviZ
