Solved Flowroute trunk registration not heeding Registrar setting
lfr1138
I am getting the following error in the event log 2 - 3 times per minute:
SIP Server/Call Manager ID: 12293
Registration at Flowroute has failed. Destination (sip:216.115.69.144:5060;transport=TCP;lr) is not reachable, DNS error resolving FQDN, or service is not available.
The problem is that 216.115.69.144 is the address for sip.flowroute.com (which I believe is being/has been retired, which may be why I started seeing this recently) and not us-west-or.sip.flowroute.com (which resolves to 34.210.91.112) as is set as "Registrar/Server/Gateway Hostname or IP" in my trunk configuration. Also, I seem to be unable to override the "Outbound Proxy" setting to match as it always reverts to sip.flowroute.com after I save the settings. I made the change to my configurations to use us-west-or last year with the notifications to do so from Flowroute/Interado and everything had been working, but have had registration issues for the last couple weeks that I noticed. As of now, I get a busy tone when attempting outbound calls, but some inbound seem to get through, but maybe not consistently.
I am currently running version 16.0.5.619 on a local Debian Virtualbox VM.
Thanks for the info! I'll do the upgrade and trunk reinstall later tonight and post back any results.
I have been running on this hypervisor for a couple years now with no real issues before this one, so likely not an issue, but I may be able to get KVM to run on the host as a last resort.
Sure, leave the hypervisor as the last step and see if the upgrade and trunk rebuild using defaults works.
After getting up-to-date with the latest (non-Alpha) version, I tried updating the proxy setting on the trunk to us-west-or.sip.flowroute.com before doing the delete/re-add, just to see, and the setting saved/ registered immediately. So, it looks like I am good to go!
Thanks again for the assistance!
Reactions: JohnS_3CX
kanderson
