FTP Transfer Log
Rhys Haskell
We have recording archiving enabled, although the recordings do not seem to be moving to the remote FTP server.
Is there a log that shows us why this is failing as the IT company say everything is okay there side?
If everything was ok it would be working. The FTP server should have logs which would probably be more useful. You can't really make any changes in 3CX other than path/folder/credentials but they can probably make changes in the FTP server if needed.
Thanks for this, I was just hoping there was a log so that I could prove to them it was there problem. I am sure there is not issue on the 3CX side.
Well I'm assuming if they are providing the FTP they are probably managing the firewall in front of it as well. So if they aren't even seeing attempts it's not a FTP problem but it's still their problem.
@Rhys Haskell
Just a suggestion, if you are familiar with wireshark you could perform a packet capture on the 3CX PBX and then attempt to archive a recording. The communication between 3CX and the FTP server should be visible in the packet capture and it may shed some light on what the cause of the issue might be.
jmarshall
