Gateway status in SIP trunk menu is red !
mohammadreza_yr
Hello. I have a problem with Newrock PSTN (FXO) gateway on 3CX. After 4-5 hours of working properly, gateway light status in SIP trunk menu changes to red. after that, I can receive outbound calls but I cannot make outbound calls. Can anybody help me, please?
11361
I assume you mean you can receive inbound calls but not make outbound calls. If you reboot the gateway does it go green? You might want to think about using a supported gateway.
Check the 3CX Activity Log to see if the gateway has been re-registering on a regular basis, then stops. This would be why the status turned red, if 3CX were expecting a re-registration , but didn't receive one. It might also happen, if you placed a call, but there was no response from the gateway. Then you may want to check and see if the gateway has an internal log system that may provide some information.
Check in dashboard if GW IP has not been blacklisted
thank you for your quick answer. I should say YES, if I reboot GW, status changes to green.
[email protected].
