Gigaset N670 Pro loses settings for handsets
beyond2
New User
I support a company and I have set up 3 new handsets on the N670 Pro.
Basically I did it like this: https://www.3cx.com/sip-phones/gigaset-n670-n870/#h.qjk51y62i09l
And entered the access data for this, so #extension, auth username and password of 3cx. Now this data has disappeared again! Everything worked, but overnight it seems that these data have deleted. The handsets are apparently still registered in the N670, but the data is missing.
beyond2
Yes, the SIP accounts will follow the same order like you add them in the FXS DECT page of 3CX.
So if you reset and reprovision the base with account 1 until 8 you will then see them appear in the XML.
But I am worried that you made too many changes in the N670, so I suggested to do it fresh from the beginning so we can avoid too much troubleshooting.
I didn't make any changes. I had a fresh install and the only setting I changed was the one I showed you. But I reprovisioned again.
Is there a way to trigger the provision of SIP accounts manually with ssh (cli)? I don't want to interrupt business.
Nope, it has to be done manually when the device is idle.
I think it will not provision or reset if there are active calls.
Finatra.us
