google client instant how to delete
mmb
hi,
i installed the 3CX server on the provided trail google instance , i would like to know for how many months this trail last?
I also installed on my Azure account and now it's the two servers conflicting over the domain , so how to delete the the google server provided by 3CX?
If you followed the guide and setup the 1 year free service it lasts for 1 year. You'll need someone from 3CX to shut it down. The other option is you can release the FQDN associated with that key, get a new key and reinstall in your Azure account to keep the FQDN.
i used the 3CX instance not my account , i follwoed the PDX express installer.
i got this from the email
Option 3: Cloud - Try it hosted by 3CX
Free hosting by 3CX for 3 months, then migrate it to your account or on premise.
GET 3CX on GOOGLE
So it will run for 3 months or until you can get someone from 3CX to shut it down. @JohnS_3CX
Hi @mmb
The 3CX-hosted free Google instance will last for 3 months unless there is no call activity for a long while it may be deleted automatically.
Your key remains valid though, so you can deploy it on your own hosted instance (PBX Express or manually) or you can deploy it on a local machine.
RicoDinero
