Grandstream DP750 and DP720
Simon Phelon
Intermediate Cert.
It took a bit of mucking around to get the DP750 setup but with a DP720 is now it is working fine as an extension.
I see though that the DP750 can support up to 10 accounts but doesn't appear to be an installation option under add FXS/DECT. Is there a template for the base unit that I have to upload or am I looking in the wrong place?
Hello @Simon Phelon
Please note that the Dect phone you are using is not a supported 3CX device which means that a template is not included in the system. You will need to configure the device manually to get it to work. The list of supported devices can be found here: https://www.3cx.com/sip-phones/
megalmazan
