- Joined
- Oct 21, 2019
- Messages
- 27
- Reaction score
- 3
I am trying to install a HT802 with 3CX hosted in the cloud. I followed the steps but was unable to get it to work. Any suggestions.
3cx is hosted on amazon lightsail. Should the Grandstream device be connected to 3CX via VPN you meanConnected to the cloud in what method ? VPN is the only supported method for cloud connection.
You are going to have to provide some more information about what you have tried, and the results so far. As a starting point, do you see an incoming registration attempt in the 3CX Activity Logs? If not, then you need to figure out why. Is it a firewall issue at the server end, or the ATA is not "pointed" to the correct destination? Have you tried both the public IP and FQDN of the server?
Thank you for the reply, I am using it for a fax machine. Is the VPN supposed to be setup thru the 3CX interfaceVPN is the only supported method for any gateway or ATA back to hosted 3CX.
This does not mean that you wont be able to get it working using STUN or SBC however if you were to ask 3CX to support such a setup they would say no.
Note: if using FAX with this ATA then avoid STUN/SBC.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
