  • V20 Update 10 Final Learn more
Solved Grandstream Provisioning 3CX v18
CPMM
Platinum Partner
When I try to change a setting on a user account where the user has Grandstream phone, I have been getting an RPS failure today. Also, manually entering the provisioning link on the phones does not seem to be working.
Getting this on multiple systems.
Is this a failure on Grandstream's part and does anyone else have any knowledge if they are working on a resolution?
Thanks.
Yes it was, but it is now resolved after we informed them about it. If you try again your should see in your Event Log that the MAC was delivered successfully to the RPS.
Reactions: CPMM
BConveryCoreCare
