Greetings, Unavail & Recording Message
OS-Milton
16.0.641
Problem 1
had reports of our Call by Name wasn't working
Client had reported previously but no log / email was ever generated - No Post information on timeline.
read a few items - found must have Greeting recorded..
Found No greetings on many lines I know they were setup on previously before update / upgrade (at least I thought they were)
Looking deeper - saw that many Unavail were also missing.
Problem 1 - solved - place a greeting and problem solved
Problem 2 - Try to Record a new greeting
after all prompts hit 0 to record new greeting hit pound to stop recording ~3 seconds later it acts like # was hit .. it wasn't no new recording
Same for Unavailable greeting.
Only using the webclient and setting up recordings via that do I get the ability to record greeting / unavail msg and works correctly.
using yealink / 3cx softphone for operaions.. also tested via 3cx android - same thing
What Yealinks and are they on latest FW / Default templates?
you could run a pcap off the Yealink from the GUI and press # and see what it shows in Wireshark.
T42G - 29.83.0.130 - will give that a shot...
noticed greetings are not sticking or being removed...
I moved old greetings from old system into directory renamed to match correct naming convention..
worked fine for months until Update 16 last month... now all sorts of issues...
will have to check if greetings.xml settings
Hi @OS-Milton
Please reset and reprovision the phone, not with custom templates.
Then try again. The DTMF commands should reach the PBX as RFC2833 and this action should confirm that the phone is configured to do so
Why would I re-provision a phone?
The issue occurs on ALL Devices / Android / softphone / Handset...
updated current version 16.0.655 - Issue still persists...
-- Resolution --
Delete Existing Message via prompts then will record new without causing the auto end ...
the issue is in the PBX not the phone -
the test for that is - Test from alternate softphone -
could still be extension config issue - but more 3cx..
also the previous update apparently DID delete messages and greetings....
noticed that in the release notes....
swegner
