GXW4104 and 3CX V20
sandyhardi
SOHO User
Hi Team,
We have a configuration for Singtel Analog PSTN connected to FXO.
Inbound call is working. However, outbound call is not. attaching the configuration.
this is also the wireshark capture
Hello sandyhardi
You have give mutch information, that is great.... but exactly what is not working?
It seems like you can dial out?
Can it be:
-Wrong number
-Inbound information
-Audio one way
-No audio
-Wrong codec
-No outbound rule
Let us know what is happening
Paulo
1. The registrar server is wrong - it has to be only the IP of the of the GXW4104. Fix this first and try again.
2. In the capture you show the call from the Grandstream GXP2170 desk phone to the PBX.
But you should instead look at the capture from the PBX IP address to the GXW4104 IP. These are the ones that will tell you if a call left 3CX and went to the Gateway, and what reply it got back.
Reactions: paulodagraca
JohnS_3CX
That is sharp!
For sure, you already had your coffey today xD
FXO should also be set to one stage dialing.
I also see a prefix to specify the port option, you may have to test to see if the FXO actually wants a prefix, for the call to proceed.
Hey guys! i made the outbound and inbound work! thanks for your inputs!
outbound calls works well.
inbound calls work, however CID is set to unknown, any advise?
Don't forget the calls come in via PSTN, so maybe the provider is not sending caller ID or they may be sending it in a standard that the FXO does not understand, so it has nothing to show to 3CX.
If your provider is sending CID in the Bellcore format, then the gateway must wait a few seconds before passing the call on to 3CX, as it must capture the CID info sent between the first and second ring.
As I recall, the option may be "number of rings before pickup". Try setting to 4, then lower, to 3, then 2, to see if it still works.
x1515
