Hacked Account
Den1s
Hi, I was recently hacked and a number of calls were made by a rogue caller and ramped up quite a bill. Having looked in my logs I have the following information. How can I prevent these numbers from being called? I dont understand what was done here, can someone please explain.
09/04/2019 13:12:5400019096104712000900447452010034[19096104712]_000-900447452010034_20190409111254(61).wav
09/04/2019 13:12:4600019096104712000900447452010032[19096104712]_000-900447452010032_20190409111246(59).wav
09/04/2019 13:12:4200019096104712000900447452010031[19096104712]_000-900447452010031_20190409111242(58).wav
09/04/2019 12:36:1000019096104712000900447452010034[19096104712]_000-900447452010034_20190409103610(55).wav
09/04/2019 12:36:0300019096104712000900447452010032[19096104712]_000-900447452010032_20190409103603(54).wav
09/04/2019 12:35:5700019096104712000900447452010031[19096104712]_000-900447452010031_20190409103557(53).wav
09/04/2019 12:34:3200019096104712000900442033477788[19096104712]_000-900442033477788_20190409103432(51).wav
09/04/2019 09:30:5900019096104712---972597662175000900447452010034[19096104712---972597662175]_000-900447452010034_20190409073059(45).wav
09/04/2019 09:30:1900019096104712---972597662175000900447452010032[19096104712---972597662175]_000-900447452010032_20190409073019(39).wav
09/04/2019 09:30:1100019096104712---972597662175000900447452010031[19096104712---972597662175]_000-900447452010031_20190409073011(37).wav
09/04/2019 09:10:3100019096104712---972597662175000900447452010032[19096104712---972597662175]_000-900447452010032_20190409071031(33).wav
09/04/2019 09:10:2800019096104712---972597662175000900447452010031[19096104712---972597662175]_000-900447452010031_20190409071028(32).wav
09/04/2019 09:10:1000019096104712---972597662175000900447452010034[19096104712---972597662175]_000-900447452010034_20190409071010(31).wav
09/04/2019 09:10:0500019096104712---972597662175000900447873011004[19096104712---972597662175]_000-900447873011004_20190409071005(30).wav
09/04/2019 09:10:0000019096104712---972597662175000900447873091022[19096104712---972597662175]_000-900447873091022_20190409071000(29).wav
09/04/2019 09:09:0400019096104712---972597662175000900448009879077[19096104712---972597662175]_000-900448009879077_20190409070904(23).wav
this alone does not tell us much.
this looks like a recording log maybe?
the activity log might have some more info.
in the 3cx extension list - are there any of these?
10251
If so you need to change your credentials to something more difficult using the regenerate button.
You may have a few issues to deal with.
How did they get into 3CX? the Activity log should show where the calls originated.
Did they guess a password and register a set? Was this an "inside job"?
Are the numbers they called dial-able by anyone (extension), this can be limited in the outbound rules and should be done, in particular, for high value numbers. 3CX can also prevent calls to certain regions/countries not normally called. Very expensive calls (high value numbers) can usually be blocked by your provider as well.
fransisco
