Handsets not reverting to primary internet connection after backup internet has been used.
Darkneopulse
Hi All,
To get this out of the way first, I understand that this is probably a networking issue rather than a 3cx or handset issue but I'm struggling to find a solution on the network side, so maybe there's something I'm overlooking on the 3CX side I haven't thought of.
The issue I am facing is that many of our clients that have 3CX systems also have a backup 4G internet connection for when their primary internet fails over, so normally our sites look like the below:
Bridged Modem & 4G Modem ---> Sophos XG or Unifi USG ---> Rest of the network.
The 4g failover is working as intended, the primary connection goes down and all traffic including 3cx is routed out the 4g, the issue is once the primary internet comes back online all traffic EXCEPT 3cx reverts to the primary connection, I have had times where after a full week I have had to physically unplug the 4g backup to force the traffic out of the primary connection.
This issue occurs on both the USG & the XG Firewall when set to "Serve new connections through restored gateway", even with customized weights, when set to "Serve all connections through the restored gateway" this issue doesn't occur but it drops any active calls when the primary connnection comes back online.
Any help or guidance with this issue is greatly appreciated.
  • 3CX Version, Professional Annual 16.0.1078
  • Server OS, Debian 9
  • Is the 3CX Server Hosted and where? Hosted with GCP
  • IP Phone Make/Model/Firmware: Yealink T48s latest 3cx firmware, occurs with T42s latest firmware too.
  • Provisioning Method: Local / VPN / STUN / SBC: STUN
  • Trunk Provider or Gateway Make/Model
  • Are custom Phone Templates being used: YES
If it's failover, how is traffic going out the router at all? Shouldn't the 4G/WAN2 interface be down?
That should be the case but from what I can see it is staying on until all active connections are closed by the "Serve new connections through restored gateway" setting which is the case for both USG and XG, when I check the 3CX console they still display the 4g Public IP address on the "Phones" tab.
florentrobineau
