Has anyone seen this? Gemini Speech Sensitivity?
UCMUserAZ
I have been testing a few gemini call scripts with 3cx this week. Very powerful and awesome I have to say. It seems the speech sensitivity once connected with Gemini is really touchy. Testing without speakerphone it works really good. When on speakerphone (iOS latest; 17pro) Gemini can interrupt sometimes. I tested with just a simple greeting and it sometimes repeats. If I put speakerphone on with the mic muted, it works 100%. Not sure if the iphone mic is picking up the speakerphone audio or what or an iphone issue. I don't think this is anything on the 3cx side, but just how Gemini is listening. I see gemini has some realtime_input_config settings around: https://aistudio.google.com/docs/live-api/capabilities
  • activityHandling (NO_INTERRUPTION)
  • automaticActivityDetection.startOfSpeechSensitivity
  • automaticActivityDetection.endOfSpeechSensitivity
  • automaticActivityDetection.silenceDurationMs
I do not think 3cx exposes these settings through StartGeminiVoiceSessionAsync() or global parameters. Do you think it would be possible to add support for passing realtimeInputConfig when initializing the Gemini Live session? Only reason I ask, I know some of our callers use speakerphone and we would hear this feedback from them on the Ai voice agent. Not sure if Grok or OpenAi also have this kind of sensitivity.
If anyone out there has a gemini call script, I would be curious if speakerphone produces the same? It is just odd where if I mute the mic on speakerphone it works perfect so would not think anything in my prompt.
Thanks in advance!
Teresa Nguyen
