Solved have "Call Only" option for wordpress live chat?
askandasnwer
New User
At the moment there are 3 options in the wordpress live chat
chat only
phone and chat
and video, phone and chat.
Isn't there a option for just call?
Is there anyway we can implement just call function?
A feedback will be highly appreciated.
Thank You
Just don't use the plugin if you just want calls.
Or use Click2Talk links.
Thank you for the prompt reply.
Can you suggest whar that would be?
When i use thr direct link still it has thr chat box.
No Call only option can be seen
Thank you
this is because we want to use the ip phone extension and it wont be able to receive messages
Are you talking about this option?
Yes! I support his is what is required. where is this option?
Please help.
Thank you
From the admin login of your WP site:
Thank you very much! This solved the issue. Also is there any setting like this directly from 3cx panel? So only the phone works through the Clcik2talk link?
Thanks.
Glad it worked!
Not sure what you mean. What do you want to achieve?
This worked perfectly with the plugin. Actually the issue was I couldn't access the settings page of the plugin initially but this was solved after clearing the cache.
Working perfectly fine now.
Thank You
Finatra.us
