Having trouble making and receiving calls.
jsadan said:
13:12:14.765 [CM503016]: Call(43): Attempt to reach <sip:1805*******@192.168.xx.xxx> failed. Reason: Not Found
13:12:14.750 [CM503003]: Call(43): Call to sip:805*******@lax.teliax.net:5060 has failed; Cause: 404 Not Found; from IP:8.3.252.xx:5060
13:12:13.500 [CM503025]: Call(43): Calling VoIPline:805*******@(Ln.10000@Teliax)@[Dev:sip:m(last name)@lax.teliax.net:5060]
You are dialling 1+ BUT your outbound rule is stripping off the first digit (the 1) and sending the remaining. I suspect that they want that 1 as well. Change the rule to strip zero digits.
jsadan said:
Also still having trouble with inbound calls, rings about 6 times then says all circuits are currently busy.
Did you define where an incoming call on that trunk is supposed to go? An extension, a ring group?
Yes, I have it set to a ring group I made with my extension in it.
I got outbound calls to now work. I appreciate all the help from you.
