- Joined
- Jan 1, 2020
- Messages
- 84
- Reaction score
- 21
I've followed the steps of the Code Generator, but the code is not working in my Wix website and they told me that can't give support third party code.
How can I get the Live Chat Code in HTML?
See the reply from the WIX Support:
Hi!
Thanks for waiting while our team investigated your case.
We checked the problem video. I see that you are trying to add third party code to the Corvid code panel. Note that Corvid only supports JavaScript with the limitations described here (https://support.wix.com/en/article/corvid-javascript-support). In addition, we are unable to provide support for third party codes that were not created or tested by Wix.
However, if we understand correctly, you want to embed a third-party chat application on your Wix site. We recommend incorporating it using an iFrame. Click here (https://support.wix.com/en/article/wix-editor-using-iframes-to-display-visible-content-on-your-site) to learn how.
We hope this answer has been helpful.
Feel free to return to us when necessary.
Regards,
Wix.com"
Hi!
Regards,
Wix.com"
