Holiday Manager (powershell script, with GUI)
GMark
Hi all,
Attached a powershell script to manage your holidays, hope it helps.
By the way, it contains some code from the famous @fxbastler :)
Regards
Thx! Seams to work. Great work!
Just for Info: When you enter a new Holiday and the WAV File does not exists, you will get this Error...
OfficeHolidays[0].HolidayPrompt:
WARNINGS.XAPI.NOT_FOUND
- OfficeHolidays[0].HolidayPrompt: WARNINGS.XAPI.NOT_FOUND
When you add new Holiday, the HolidayPromt is automatically filled out with "prompt.wav" and this WAV File does not exist. So just fill the Field with an existent WAV or leave it empty
Reactions: GMark
Is token the TOTP code?
I can't login
Error 3CX login: The remote name could not be resolved:'https'
then removing https:// from my URL
Error 3CX login: Unable to connect to the remote server.
Yes, Token is the TOTP code.
Error: did you try to completely close powershell, then try again (without https:// prefix)?
When you are not using default HTTPS port, you also need to enter the HTTPS port like 3cx.at:5001
I was using the port the whole time, but yes, closing powershell and trying again without the prefix worked.
BConveryCoreCare
