Hosted PRO Trial – Lost System Owner/Admin Access
Mschreuder
Trial User
I have a 3CX PRO 8SC trial Hosted by 3CX. The system is currently running normally, but I have lost access to the PBX Admin Console/System Owner account.
FQDN: net2026.oh.3cx.us
I can successfully log into my 3CX Customer Portal and the system appears there as Hosted and Running.
The PBX Forgot Password function does not result in a recovery email being received.
I need assistance recovering or resetting the System Owner/Admin credentials without reinstalling, deleting, restoring, or otherwise modifying the existing running PBX.
I also have a recent downloaded PBX backup.
Can 3CX reset/recover the System Owner credentials for this Hosted by 3CX instance?
Hi @Mschreuder you will need to open a support ticket with us so we can assist on this matter.
Have a good day!
I am not sure how to open a support ticket. This screenshot makes it look like I can’t IMG_9405.jpeg
https://www.3cx.com/ordering/
You dont get included support in a trial, so you will need to purchase a ticket.
since you're trialing you'd be better off spinning up a new one.
Ok. If I create a new trial can I restore the backup I made ( I stored a copy on my pc)
If its a 3CX backup then you can restore a 3CX backup. However, Im not sure if its possible in a Hosted Pro trial as i've never done it. Assume your backup is pre messing with email settings?
The backup was made after the login/password-reset email problem had already started. I was still logged into the Admin Console through an existing Edge browser session at that time, so I made and downloaded a full backup before that session was eventually lost.
My concern is that if I create a new trial and restore that backup, I may also restore whatever System Owner/email/login configuration is preventing me from recovering access now. Would restoring that backup put me back into the same situation, or will I be able to establish new System Owner credentials when creating the replacement trial?
@@Mschreuder
Before reinstalling, please contact our CSR team via the contact form with email issues on trial subscriptions; they will advise.
@@Mschreuder did they provided/reset password or you was need to create new trial?
I have same issue that's why I'm asking to know shall I wait to they reply or start creating new one :)
Carlos - EC Mates
