How do I test the free license before the trial expires?
TaCito
Forum User
We have a 3CX system that was set up last year and is currently on the 1-year trial license. Based on our usage from the last year, I think the free license with 8 simultaneous calls is sufficient for our needs. I want to make sure the transition from the trial license to the free license happens as smoothly as possible.
Is there a way to downgrade the license before the trial expires? I don't think we're using any pro-level features, but I want to make sure nothing breaks. Can I immediately switch back to the trial license if something does break?
Thanks.
if you are not you using :Queues,Bridges,Recordings
then you can stay in Free STD licence, no feature will be disabled from what you use for now.
For licence change i don't know what could be wrong but even if not necessary do a backup almost in worst case you have something to restore.
You can test the free license by simply applying for another license using a different email and then restoring your backup using that license. But if it's that big of a concern, then pay for a license.
Hi @TaCito
In addition to the above, please note that only V16 PBX licenses will downgrade to 8SC
If you are on V15 then they will be downgraded to 4SC
Call_Flow.co.uk
