Frank86 Bronze Partner Joined Jan 18, 2018 Messages 300 Reaction score 26 Jul 24, 2020 #1 If I have a PRI SIP trunk, which allows 23 sim calls, but only need 10-12 for now, is there a problem ordering 3CX with 16 sim calls?
cobaltit Platinum Partner Advanced Certified Joined Mar 22, 2012 Messages 6,735 Reaction score 2,324 Jul 24, 2020 #2 Is it a problem when you turn on your sink and only put an 8oz cup under the faucet? The answer is no. Your maximum call capacity is limited to the lowest common denominator. In this case it would be the 16 SC license. Reactions: Frank86
Frank86 Bronze Partner Joined Jan 18, 2018 Messages 300 Reaction score 26 Jul 24, 2020 #3 Great. Thought so. Just wanted to confirm.
CentrexJ Titanium Partner Advanced Certified Joined May 5, 2009 Messages 1,251 Reaction score 698 Jul 25, 2020 #4 Also make sure you factor in that a 3CX 16 sc license is for all calls (pri, internal and sip). So while you may be able to make 16 calls over the pri, it would only happen if there isn’t additional extension to extension calls at that time.
