Solved How to change 3CX server public IP address from static to dynamic
ashwingorityala
SMB User
Can anyone guide me How to change 3CX server public IP address from static to dynamic
Within 3cx management console , Under Settings >> Network >> External IP Configuration is it set to dynamic. do not change the stun settings
if you are using a 3cx fqdn , Std and pro may take 6 hrs for the fqdn to update , enterprise license is 6 mins
I have a DYNDNS how can i update
The beautiful part of using a 3CX FQDN and setting 3CX to Dynamic IP is that it does the DYNDNS for you, as well as the SSL certificate. It removes all of that complexity for you.
If you do have frequent IP changes though I would strongly recommend you go with an Enterprise license for a 5 minute TTL.
Now I've changed to dynamic IP, where should I insert my dynddns?
If you are using a 3CX FQDN you don't, it uses its own dyndns type service and updates the fqdn to point to the changed IP address as needed.
If you are using a 3cx fqdn, 3cx does the dns updates for you
if you are using your own fqdn, you have to manually change your dns record , 3cx does not support any Dyndns services within the product
I get this errors when i select dynamic ip
Does the 3cx server have internet access ?
change the network card dns settings to google - 8.8.8.8 and 8.8.4.4
Please provide info on your setup as per info here https://www.3cx.com/community/threads/information-to-provide-when-requesting-help.67558/
  • 3CX Version, Standard Annual18.0 Update 3 (Build 461)Version
  • Server OS, Windows 10
  • Is the 3CX Server Hosted and where? On-premises
  • IP Phone Make/Model/Firmware version, Softphones, apple and android
  • Provisioning Method: NA
  • Trunk Provider or VoIP Gateway Make/Model, BSNL India
  • Are custom Phone Templates being used: No
Yes, I have internet access, and I'm able to access the portal remotely, also I'm able to register and make calls from a softphone.
I'm updating the IP regularly to get access, If I set the IP to dynamic I see these errors
on the 3cx server
1. can you ping stun2.3cx.com , stun3.3cx.com - does it return an ip address
2. Run nslookup for stun2.3cx.com , stun3.3cx.com - this command should return the IP address of these fqdn
3 run tracert for stun2.3cx.com , do you see a list of servers
if none of the above returns any info, you have a internal network issue
are you using your 3cx fqdn or you own ? Could your dyndns setup be causing issues
Reactions: ChrisC_3CX
on the 3cx server
These are the results from the 3cx server.
I'm using a Fortigate Firewall, everything is configured properly.
From your screenshots it seems that you can resolve the STUN FQDNs but not always indicating that you may have intermittent network issues.
Do you have another PC/Server on the same network, do you get more or less the same results if you make the same tests from there? If yes, you might actually want to consider taking a closer look on the network level.
I'd also suggest doing a few nslookups for unrelated domains too such as google.com or microsoft.com to see if you get timeouts there too.
Also, do flush your dns before testing with:
ipconfig /flushdns
Note: Our stun servers will not respond to ping so timeout there is expected.
I would say you have internal network issues, as nslookup are not returning results.
I've set to automatic dns and i get these results
I've set to automatic DNS and i get these results
I've tried the same from other PC with automatic DNS the results are the same as screenshots
I'll PM you for a bit more info on this.
Can you please help me find out, it is allowed to make calls
I've just replied in our PM conversation for something to try so please take a look there.
After taking a closer look at this with @ashwingorityala we identified that the issue was caused by a Wi-Fi adapter that was connected to the 3CX Host. It was not connected to a network at all but still caused issues so only by disabling it completely we were able to resolve the issue.
For anyone else reading this do bear in mind that we do not support the use of wireless adaptors on the 3CX Host and it would be best to avoid connecting them altogether.
I'll be marking this as solved for now so please let us know if anything else comes up by starting a new thread!
Ahzaz
