How to change system time 3CX v20 debian
bytesolutions
Good morning everyone.
A few days ago I changed the server of my 3CX v.20 debian configuration and inadvertently I didn't notice that the new server has a totally wrong date and time set. How can I fix it remotely? 3CX web interface or terminal?
Thank you all
The server time zone can be set from the 3CX server options
The actual server clock will need to be done from within the Operating System itself.
Check your host time if using hyperv.
Thank you. This is the function I need. Unfortunately, I don't have access to the command line of the PC with 3CX on board (it's 30km away).
I saw that it is possible to access Debian via SSH, unfortunately the SSH port on Debian 12 seems disabled by default. Can you confirm?
Do you know another way to access the Debian command line remotely?
Thank you very much
As far as I know if installed from 3cx iso, SSH is open, as of v18, I just did upgrades not fresh install
Reactions: bytesolutions
I confirm that SSH is open. I connected via SSH a little while ago, I adjusted the date and time and now the system works perfectly! I took the opportunity to also enable NTP client.
Thank you very much!
BR
Urs_S4A
