How to delete network provisioning interface
Integra
Where in 3CX can you delete entries for the network provisioning interface? For example, under Phone Provisioning > 3CX App, under Network interface for registration and provisioning there is a drop-down menu with multiple interfaces. I had created a wrong DNS entry when I had first installed 3CX and would like to remove this entry.
If you set it up as split DNS during the setup wizard you cannot remove that entry.
That gets defined during the setup, so for that one specifically you will have to reinstall and choose the correct settings in the wizard.
But if you have multiple NICs you are not using, you can disable them so they are no longer available to the system, and reboot (applies to NICs only - not split DNS entries).
AshleyStokes
