How to export contact data
Andreas123
New User
Can't find where you export contact data from? To xlsx/csv. Please can someone link a walkthrough to how to export Saved Contacts, or let me know how? Thanks in advance!
Can you please clarify which saved contacts you are referring to?
The method to export saved contacts data to a file format such as xlsx or csv can vary depending on the platform or service you are using to manage your contacts. Here are a few general steps for a few popular platforms:
Google Contacts:
  1. Log in to your Google account.
  2. Go to Google Contacts (contacts.google.com).
  3. Select the contacts that you want to export.
  4. Click on the "More" button (represented by three dots) on the top left corner and select "Export".
  5. Choose the file format (xlsx or csv) and location to save the exported file.
Outlook/Microsoft 365:
  1. Log in to your Microsoft account.
  2. Go to the Outlook Contacts page.
  4. Go to File > Export.
  5. Choose the "Comma Separated Values" option and select the location where you want to save the exported file.
Apple Contacts (Mac):
  1. Open the Contacts app on your Mac.
  2. Select the contacts that you want to export.
  3. Go to File > Export > Export vCard.
  4. Choose the location to save the exported file.
Note: If you are using a different platform to manage your contacts, I suggest checking the platform's support page or help center for more information on how to export your contacts to a file format such as xlsx or csv. In addition, check LinkedIn sales navigator add to chrome tool that will considerably relieve you work.
ARKC
