How to fix 3CX after factory resetting windows (installed on secondary drive)
jkb2005
Hello, I have 3CX installed on a secondary drive, and had to factory reset the C: drive. All the services seem to be in the folder of 3CX, but how do I get them to start automatically?
You could try to do a a fresh install of 3CX and point it at the 3CX folder but realistically this is when you would just restore your backup.
As above, you are better off restoring from a backup.
There maybe system files that get installed on the C: drive, during the installation - along with firewall rules
Wecare_ITA
