How to manually update SSL certificate on v20 self-hosted 3CX?
it.support
Hi all, we've updated our self-hosted 3CX instance from v18 to v20 last year. Our SSL certificate have recently expired so I tried to update it using same method in the previous year to no avail.
I would usually log into the server. Copy fqdn.key file and fqdn.pem file to C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1 and rename the respective files to fqdn-crt.pem and fqdn-key.pem to match. Then restart the "3CX PhoneSystem Nginx Server" service.
We're running 3CX on Windows server 2016 and I used instructions from these posts in the past to update the certs:
https://www.3cx.com/docs/renewing-ssl-certificate/
The first link is no longer available, so I wonder if the instructions have changed. I couldn't find anything recent on 3CX forums regarding renewing SSL certificates on Windows. Hoping you guys can point me in the right directions.
In Version 20 the certificate files are in C:\ProgramData\3CX\Bin\nginx\conf\Instance1
About the names and location for nginx and sips certs you may look at this linux example:
https://www.3cx.de/forum/threads/ssl-certificate-erneuert.114018/post-441718
edit for Windows (we use powershell there):
C:\ProgramData\3CX\Bin\nginx\conf\Instance1\domain_cert_<fqdn>.pem
C:\ProgramData\3CX\Bin\nginx\conf\Instance1\domain_key_<fqdn>.pem
C:\ProgramData\3CX\Instance1\Bin\Cert\domain_cert_<fqdn>.pem
C:\ProgramData\3CX\Instance1\Bin\Cert\domain_key_<fqdn>.pem
Reactions: it.support
clientcert-renew-pbx.domain.de.ps1
Code:
# Pfad zur NGINX-Konfigurationsdatei
$nginxConfigFile = "C:\Program Files\3CX Phone System\Bin\nginx\conf\nginx.conf"
# Pfade der 3CX Zertifikate
$sipCertDir = "C:\ProgramData\3CX\Instance1\Bin\Cert"
$sshUsername = "sshuser" # Benutzername für Let's Encrypt Zertifikate
$homeDir = "C:\Users\$sshUsername" # Angenommener Pfad für die Let's Encrypt Zertifikate
# FQDN und Zertifikat-Pfade initialisieren
$fqdn = ""
$nginxCertPath = ""
$nginxKeyPath = ""
$actCertPath = "$homeDir\$fqdn.fullchain"
$actKeyPath = "$homeDir\$fqdn.key"
$sipCertPath = "$sipCertDir\domain_cert_$fqdn.pem"
$sipKeyPath = "$sipCertDir\domain_key_$fqdn.pem"
# NGINX-Konfiguration einlesen
$nginxConfigContent = Get-Content -Path $nginxConfigFile
# FQDN, Zertifikat und Schlüssel extrahieren
foreach ($line in $nginxConfigContent) {
    if ($line -match 'server_name\s+([^\s;]+);') { $fqdn = $matches[1] }
    if ($line -match 'ssl_certificate\s+"?([^\s;]+)"?;') { $nginxCertPath = $matches[1] }
    if ($line -match 'ssl_certificate_key\s+"?([^\s;]+)"?;') { $nginxKeyPath = $matches[1] }
# Aktuelle Zertifikat-Hashes berechnen
$actCertHash = (Get-FileHash $actCertPath -Algorithm MD5).Hash
$actKeyHash = (Get-FileHash $actKeyPath -Algorithm MD5).Hash
# NGINX-Zertifikat-Hashes berechnen
$nginxCertHash = (Get-FileHash $nginxCertPath -Algorithm MD5).Hash
$nginxKeyHash = (Get-FileHash $nginxKeyPath -Algorithm MD5).Hash
# SIP-Zertifikat-Hashes berechnen
$sipCertHash = (Get-FileHash $sipCertPath -Algorithm MD5).Hash
$sipKeyHash = (Get-FileHash $sipKeyPath -Algorithm MD5).Hash
# Überprüfen, ob die Zertifikate nicht übereinstimmen
if ($nginxCertHash -ne $actCertHash -or $sipCertHash -ne $actCertHash -or $nginxKeyHash -ne $actKeyHash -or $sipKeyHash -ne $actKeyHash) {
    # NGINX Zertifikate ersetzen
    Remove-Item $nginxCertPath -Force
    Remove-Item $nginxKeyPath -Force
    Copy-Item $actCertPath $nginxCertPath
    Copy-Item $actKeyPath $nginxKeyPath
    # Berechtigungen setzen
    icacls $nginxCertPath /grant "phonesystem:(R)"
    icacls $nginxKeyPath /grant "phonesystem:(R)"
    # NGINX neu laden (Nginx-Dienst muss manuell neu gestartet werden)
    Restart-Service -Name "nginx"
    # 3CX-Dienst stoppen
    Stop-Service -Name "3CXPhoneSystem01"
    # 3CX SIP Zertifikate ersetzen
    Remove-Item $sipCertPath -Force
    Remove-Item $sipKeyPath -Force
    Copy-Item $actCertPath $sipCertPath
    Copy-Item $actKeyPath $sipKeyPath
    icacls $sipCertPath /grant "phonesystem:(R)"
    icacls $sipKeyPath /grant "phonesystem:(R)"
    # Dienste neu starten
    $services = Get-Service | Where-Object { $_.Name -like "*3CX*" }
    foreach ($service in $services) {
        if ($service.Status -ne "Running") {
            Start-Service $service.Name
    # Neustart des Systems, falls erforderlich?  probieren und eventuell aktivieren!
    # Restart-Computer
exit 1
Thanks guys.
I've updated the files in the new location: C:\ProgramData\3CX\Bin\nginx\conf\Instance1\
Renamed them domain_cert_<fqdn>.pem and domain_key_<fqdn>.pem
Restarted "3CX PhoneSystem Nginx Server" service via management console
After this the site have been applied with the new certificate.
x1515
