How to permanently login to Call Queue
Kwang Mien
Gold Partner
Hi.
We have agents who are on a call queue. There is no requirement for them to login or logout the call queue.
There were times when they accidentally disabled the Q letter on the web portal and not able to receive call thereafter.
Is there anyway to make the agents login to the call queue permanently ?
Thanks.
Regards,
Kwang Mien
Hi Kwang,
There is no way to login to the call queue permanently.
The agent always has the ability to log out if they want.
You could create a service (using the 3CX Call Control API) that monitors the agents status and forces them back in. That's the only option I can think of.
fransisco
