- Joined
- Oct 6, 2022
- Messages
- 40
- Reaction score
- 3
I have a secondary SIP trunk that i want to use for testing.
Im not able to get calls out of this trunk. My primary trunk is set up to route calls out my main trunk if they start with + or 0
On my secondary test trunk i've added calls to numbers starting with prefix +,0 but also have extensions 1201,1202 etc shold route out of the secondary trunk but they keep going out of the first main primary. I've tried removing +,0,11111 from the settings of the test trunk but calls still route from my primary.
If i remove +,0 from my primary trunk will that stop calls routing out of the main trunk completely? If there is no rule in the outbound then calls won't where to route out?
