How to start a raspberry pi’s server
Moto
Sorry if this is the wrong place but I setup my raspberry pi with 3CX I had restarted it to move it to the room where I am setting it up but I can’t figure out how to start the server so I can get the system up and running thanks in advance for any help
-Moto
It should start automatically
Make sure you shut down your Pi correctly before moving it to prevent any data loss.
if the server does not start, please ensure first that the raspbian has started first. You should be able to SSH in and look at what services are running with the htop command. If it is not accessible, you should connect a screen to it and troubleshoot the OS manually (regardless of 3CX at this stage)
[email protected].
