- Joined
- Nov 10, 2019
- Messages
- 18
- Reaction score
- 2
I'm currently testing a HT802 in regards to some analog faxes that a customer would like to use on different locations.
Everything seems to be currently up and running but I do have the impression that the HT802 doesn't get new settings like Time Zones and Extensions through the Provisioning.
I manually provisioned the HT802 through the XML-File I got from the 3CX.
Firmware Server Path is: [IP]:5000/provisioning/sscnr5ju5yowx/firmware/grandstream
Config Server Path is: [IP]:5000/provisioning/sscnr5ju5yowx
I changed the time zone for example. After restarting the HT802 nothing happens and the time zone doesn't change.
The Status for Provisioning states: "Not running, Last status : Downloading file from url."
I'm in the same network as the HT802 and can reach the 3CX on HTTP and can download the config file.
Firmware on the HT802 is 1.0.15.4
Is the Provisioning URL really correct as it is? Provisioning through the XML-File works well but after that if something is changed in the settings in the 3CX the HT802 won't get those settings which is not good at all because settings between those 2 will differ.
