i am having phone issues
VInce L
how do i fix the issue where i am on available status on my 3cx but when someone calls me on my direct line it goes to voicemail
but when you dial me on the profile on 3cx it connects?
its been frustrating me all morning. help would be appreciated to getting it fixed
It's entirely possible your available status is set for outside calls to straight to voicemail. It can also have nothing to do with your profile with the DID rule configured to straight to your voicemail.
Hi Cobaltit
how would i fix it? my colleagues can manage to get to me internally but if they transfer a call it goes to voicemail
You'd have to edit your available profile and make sure the setting for outside callers is set to ring your phone.
do you have instructions?
im using windows installation but i am not able to find the instructions
jmarshall
