I don't want voicemail disabled message
stephan23
We don't have personal voicemails. When a phone is busy we get a "voicemail is disabled for this extension" is it possible to turn this off and just play a busy tone?
Yes, in the Management console, go to Settings/ System Prompts Settings search for VMLDSBL and replace voicemail_disabled.wav with the destination_isbusy.wav, number_is_busy.wav or record a file you want to use
Thanks, will give it a go.
is that kind of setting change kept for ever or is it overwritten each time a pbx update is pushed?
Reactions: TBWD
I am not sure.
Okay, anyway thanks for sharing this ;)
Hi Stephan,
Since you don't use voicemail, you have to change your forwarding destinations for all your extensions to go to End Call.
The solution @TBWD gave may be easier though if you already have a large number of extensions.
Otherwise, make a new extensions to be used as a template and then copy it to the rest (by recreating them)
Thanks, you can also select all extensions, then edit and go to the forwarding tab. so you can change all extensions at the same time ;)
Reactions: JohnS_3CX
Indeed, I went the long way round :)
@JohnS_3CX
As we are on VM subject is there a way in 3CX to get simple voicemail without option to leave a message ?
If not , it surely be a small change in 3CX to add this in extensions as available settings?
swegner
