Import / Duplicate ICR's to different SIP Trunk v20
jmatano
Platinum Partner
I have a couple SIP trunks currently set up in a V20 system that I will be porting numbers over to a different SIP trunk, which means I need to import the same ICR's from one trunk to another. In V18 and before, I would export the ICR, reformat the the lines in a spreadsheet with the new trunk ID, and import the CSV. Now it seems like I can only import a .txt file with only the number itself. How do I import and assign a ICR to it on import?
Doing it one by one isn't really an option since the trunks I am working with will have between 200-1000 ICR's.
Reactions: PhoneMan123
Carlos - EC Mates
