Solved Inbound caller Is my own number
Mac Little
New User
I have a sip trunk set up with voice host and outgoing calls work perfectly however any inbound calls come through as my main sip trunk ringing itself and I have been through every setting to try rectify this and cannot figure it out so any help is much appreciated.
Thankyou
Hello, @Mac Little
You can also check whether the SIP provider is sending the calls from the main trunk number. A Wireshark capture will show you this information. Capture a call, then see the 'From' SIP field in the INVITE from the provider to the PBX.
Reactions: jed
Hi, I have sorted it, it was a setting on VoiceHost, thanks for your support.
