Inbound Rule Wildcards
Rob Turner
I am starting out on my journey with the 3CX platform but i have experience with Cisco and Siemens PABX platforms. what I am wondering is if I am able to create a wildcard inbound rule so that it will match several of the digits from the inbound string to the extensions on the system
eg
extn on system
1001
1002
1003
inbound rule
01234 66xxxx
is this possible? it something that i use on my other platforms for routing.
As far as I'm aware, the wildcards are used on the left side (beginning of number) to compensate for any provider added prefixes. I suspect that you will have to create a rule for each number. Usually people employ DIDs to be able to direct each to a specific destination.
Thanks. Can I import DIDs with a csv. That would make it a little easier. I’m considering whether this is a viable option for 2000+ company
I do not see that option under the Extension Template. But the DID's can be imported as well.
Easy to do with some Excel Formulas.
You would import DIDs under Inbound rules
Hello @Rob Turner
You will need to import Inbound rules which will also import the DIDs under the correct trunk. Create one manually and export it to see the correct format. After that you can create a file to import the rest.
Thanks for the help :-)
Glad we could assist
estrezacafe111
