Solved Incoming calls ring but get dropped on answer
neilhooper
Hello All,
I'm totally confused.
All my incoming calls get dropped immediately when answered even if left to go to voicemail.
I have looked in the logs but to honest, I don't know what I'm looking for however I did just notice this entry that I haven't seen before or maybe I've missed them previously.
20/04/2022 23:14:42 - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 178.175.134.189:52391 tid=1044477372 Call-ID=282698384-1013321809-894053176: REGISTER sip:<my-ext-ip> SIP/2.0
Via: SIP/2.0/UDP 10.124.118.53:52391;branch=z9hG4bK1044477372;received=178.175.134.189
Max-Forwards: 70
Contact: <sip:[email protected]:52391>
To: <sip:200@<my-ext-ip>
Call-ID: 282698384-1013321809-894053176
CSeq: 2 REGISTER
Proxy-Authorization: Digest
username="200,uri="sip:<my-ext-ip>",",algorithm=MD5,realm="3CXPhoneSystem",nonce="414d5359626085d122:c31e05be34c6aa27184cf518354e4105",response="e8ae31c949ce132ae0f964ac5e723801"
User-Agent: PolycomVVX-VVX_300-UA/4.1.6.4835
Content-Length: 0
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
I don't know if this has anything to do with it.
I'm running Ver 18.0 Update 2 (Build 314) on a Rapsberry Pi
Our sip provider is Voicehost (UK) 3cx Supported.
Neil
Does your system pass the firewall test?
I suspect the log you posted is a hack attempt. One big clue is that it is directed to your public IP as opposed to your FQDN. You'd need to find a log of an incoming call from your provider.
If the call is ended after it has been answered then you'll probably see a SIP BYE message from either the PBX or SIP Provider and hence determine who is ending the call.
• Try making an incoming call to the PBX.
• Go to Dashboard >> Activity Log
• Click on the Filter button and select the last call (Provided the call you just placed is still the last one)
• Go through it and look for any BYE messages (you can use CTRL+F)
Yes it does
Yes I did
I've done another test call from my mobile phone to my number which when answered produces the following:
21/04/2022 20:23:40:688 | [Flow] Looking for inbound target: called=<my-incoming-number>; caller="Neil" <sip:<my-mobile-number>@:0>
21/04/2022 20:23:40:688 | [CM503012]: Inbound out-of-office hours rule (VH) for 10003 forwards to DN:16
21/04/2022 20:23:40:696 | Line limit check: Current # of calls for line Lc:10003(@VoiceHost[<sip:[email protected]:0/UDP>]) is 1; limit is 10
21/04/2022 20:23:40:697 | [CM503001]: Call(C:15): Incoming call from Line:10003<<<my-mobile-number> to <sip:[email protected]:5060>
21/04/2022 20:23:40:697 | [CM500002]: Call(C:15): Info on incoming INVITE from Line:10003<<<my-mobile-number>:
Invite-IN Recv Req INVITE from 185.91.41.29:5060 tid=Pjbe48e0fe-23ee-45ad-a21e-a8708c230e7c Call-ID=eb481a0d-3689-4bfc-b4ce-5b2cda15c1c9:
INVITE sip:<my-incoming-number>@<my-ext-ip>:5060;rinstance=b4e9013e111624b8 SIP/2.0
Via: SIP/2.0/UDP 185.91.41.29:5060;rport=5060;branch=z9hG4bKPjbe48e0fe-23ee-45ad-a21e-a8708c230e7c
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:<my-incoming-number>@<my-ext-ip>;rinstance=b4e9013e111624b8>
From: "<my-mobile-number>" <sip:<my-mobile-number>@185.91.41.29>;tag=308e783b-d06b-4bc3-88ed-a98eb8180983
Call-ID: eb481a0d-3689-4bfc-b4ce-5b2cda15c1c9
CSeq: 15236 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: OPTIONS, REGISTER, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, MESSAGE, REFER
Content-Type: application/sdp
Supported: 100rel, timer, replaces, norefersub, histinfo
User-Agent: VoiceHost V6
Content-Length: 261
v=0
o=- 1725561653 1725561653 IN IP4 185.91.41.29
s=VoiceHost
c=IN IP4 185.91.41.29
t=0 0
m=audio 20066 RTP/AVP 8 3 101
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
21/04/2022 20:23:40:698 | [CM505003]: Provider:[VoiceHost] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:ST35205T001@<my-ext-ip>:5060]
21/04/2022 20:23:40:699 | [CM503010]: Call(C:15): Making route(s) from Line:10003<<<my-mobile-number> to <sip:[email protected]:5060/UDP>
21/04/2022 20:23:40:700 | [Flow] Target endpoint for 16 is Extn:16
21/04/2022 20:23:40:700 | [Flow] Call(C:15): has built target endpoint: Extn:16 for call from L:15.1[Line:10003<<<my-mobile-number>]
21/04/2022 20:23:40:700 | [CM503004]: Call(C:15): Route 1: from L:15.1[Line:10003<<<my-mobile-number>] to T:Extn:16@[Dev:sip:[email protected]:5062]
21/04/2022 20:23:40:700 | [CM503027]: Call(C:15): From: Line:10003<<<my-mobile-number> ("VH:Neil" <sip:<my-mobile-number>@<my-fdqn>:5060>) to T:Extn:16@[Dev:sip:[email protected]:5062]
21/04/2022 20:23:40:714 | [CM503025]: Call(C:15): Calling T:Extn:16@[Dev:sip:[email protected]:5062] for L:15.1[Line:10003<<<my-mobile-number>]
21/04/2022 20:23:40:881 | [CM503002]: Call(C:15): Alerting Extn:16 by contact <sip:[email protected]:5062/UDP>
21/04/2022 20:23:40:881 | [CM505001]: Endpoint Extn:16: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T26P 6.73.0.60] PBX contact: [sip:[email protected]:5060]
21/04/2022 20:23:45:441 | L:15.2[Extn:16] has joined to L:15.1[Line:10003<<<my-mobile-number>]
21/04/2022 20:23:45:453 | [CM503007]: Call(C:15): Extn:16 has joined, contact <sip:[email protected]:5062/UDP>
21/04/2022 20:23:45:456 | [CM503007]: Call(C:15): Line:10003<<<my-mobile-number> has joined, contact <sip:[email protected]:0/UDP>
21/04/2022 20:23:45:558 | Leg L:15.1[Line:10003<<<my-mobile-number>] is terminated: Cause: BYE from 185.91.41.29:5060
21/04/2022 20:23:45:559 | [CM503008]: Call(C:15): Call is terminated
21/04/2022 20:23:45:562 | Leg L:15.2[Extn:16] is terminated: Cause: BYE from local
I think the problem is with Voicehost as at 20:23:45:558 there is a BYE from 185.91.41.29:5060
The IP address range 185.91.41.xxx seems to belong to Voicehost so if my thinking is correct then I need to be speaking with them.
Please correct me if I'm wrong and thanks for the speedy replies.
That is absolutely correct, I would indeed recommend reaching out to them about this and see what they have to say.
Update.
It turned out to be the SRTP setting in SIPTrunks > "Sip Tunk Name" > Options, was set to enforced which meant that their end should have had RTS enabled but it wasn't. I changed my end to disabled and everything is fine.
Just thought I'd let you all know, it might help someone else one day.
Thank you for the update! I'm sure others with similar issues will find this helpful. I do have to mention though that our SIP Trunk template for Voicehost has SRTP disabled by default. That said, always make sure you're using the default 3CX template when utilizing a 3CX Supported Provider as it is with those settings the specific provider is tested and supported with 3CX.
