incoming calls
tikom
hi every one
I posted this thread before
I have a situation here, and I hope I can find an answer. I have a customer who runs a retirement home business and has his own PBX.
If someone calls the retirement house after hours, it should go to a new number that we will host on 3CX, which is not a problem. However, he wants if the first person doesn't answer, the call should be forwarded to another external number. If the second person doesn't answer, it should then go to a third person.
Is that possible?
and i received the following answer
1. Create dummy extensions with the external number as mobile, then enable "ring mobile simultaneously"
2. Create a hunt ring group which includes the dummy extensions in the right order.
everything was working fine in V18
Now i am using 3cx free which is up to 3 user and I did same setup in V20 and it's not working.
Every time someone call he hear this message "the number is trying to reach is busy"
could you please help.
Bluebox Global
