Incorrect time in web
DXC
3CX shows incorrect time in web (Call Log, System Status chart etc.)
DST option is enabled.
18.0 Update 5
Do you know how to fix it?
18.0 Update 5
Is the OS time correct? I.e in Debian or Windows?
Debian time is correct.
What's wrong about the time? Couple minutes off? Exactly 1 hour off? Something else?
Also is the NTP package installed? Static MAC address set?
The time is 1 hour low. It looks like DST is not working.
How NTP package is related to web gui?
The static MAC is never used in the large companies.
Is the Timezone in Language & Office Hours Settings correct?
If you set the timezone to a timezone 1 hour off, does everything show correctly?
3CX requires both of these to be set per their installation manual when doing on prem with HyperV. You posted in the on prem forum, but I did assume HyperV and maybe that's wrong.
I'm not saying this is the issue, I'm just asking so I can understand your configuration.
Hi @DXC
The 3CX Web UI view changes based on your own PC settings.
So if you change this and refresh the page you will see the times adjusted to your PC settings.
Real time is stored in UTC. If the Server has the correct time, and you also have the correct settings on your PC, you will see the logs appear correctly.
Reactions: IrinaP_3CX
Hi @DXC
Sorry, but this is not correct.
I changed my PC settings and web gui time is not affected in this case.
Maybe you missed something? Let's check all the basics first:
Server
- In the 3CX management console, under Settings > Language & Office Hours Settings change your timezone to the one you want
- It's a Linux based system so it will ask you to restart the services (this is necessary because we adjust Linux locales for you)
- When the services restart, you can log in again. Click Terminal in the management console and type date so you can see the server time. Confirm the server time is correct!
- Important Note: If you previously made any manual Linux changes on your own, I don't know what will happen - something may have broken and you might have to redeploy a fresh machine and restore your 3CX backup. If you didn't make manual changes via ssh terminal then please ignore this note.
Your PC
- Set the correct timezone in Windows like my screenshot example from earlier.
- Confirm your time on Windows is showing the correct time now
- If Windows asked for restart, do it
- Try to login to 3CX using Chrome, and empty the cache (or use Ctrl+Shift+R)
- If the website is not reloaded you will not see the time changing.
- As a test, you can change the windows timezone again and refresh the page - you will see the log time changing (even if the time is not the one you want)
If the server time was not correct to begin with, then the logs will have been written in the wrong time. This is not something you can fix. But the new logs written from now on will be correct.
I hope this information is helpful!
Reactions: ThomasD_3CX
Server
Your PC
Thank you for clarification.
This is Firefox related issue.
Reactions: JohnS_3CX
Hi DXC,
So I checked Firefox 111.0.1 (64-bit) on Windows, I see that it also works like Chrome and the time adjusts automatically.
Maybe you have this option enabled in Firefox? It looks like this hides your real time zone for privacy so the browser always reports UTC time.
tom.walker@blackcountryra
