Installing on an Intel NUC fails
bdgarcia
The Debian Installer boots and then I select install. I get a red bar at the top with 10 tiny unreadable screen images. I am trying to install on an Intel NUC 10i7FNH1. I just downloaded the standard production release. Any thoughts?
Usually this happens with newer computers trying to install Debian 9 that boot into UEFI mode. Need to see how to use Legacy/BIOS mode and then you Debian usually installs with no issues.
Reactions: JohnS_3CX
Unfortunately NUCs no longer support non- UEFI mode.
I think Debian10 has a bit better support for UEFI, so maybe you could try grabbing the V18 Alpha 5 ISO image from here (V18 ISO is Debian 10/Buster):
https://www.3cx.com/blog/releases/v18-alpha-5/
Yes, V18 is still Alpha, but hopefully it won't be for long and it is in a very good state despite this.
Also, you'll see if Deb10 does the trick.
zipman
