Integrating with Dynamics 365 Sales & Field Service
ecotech
SOHO User
I would like to integrate my call system with Dynamics 365 Sales & Field Service
I would like to accomplish the following:
  • When a field tech calls in they are able to type in the WO# and it will look it up in our Field Service software then route them to the correct party and/or just check them in on our end
  • Also would like for the calls to pop up on my agents Sales or Field Service dashboard (Similar to how some do it in Salesforce)
  • Would like the call information is logged and attached to the customer in our CRM
This is something that you might be able to do with a CFD app.
I'm not sure if this "Dynamics 365 Sales & Field Service" is the same that we support. The integration works with Dynamics CRM. Give it a try by following this guide:
https://www.3cx.com/docs/dynamics-crm-integration/
This is part of the integration, so if your system is supported, calls will be logged.
ICTSupport@bedfordgirlssc
