Integration with amoCRM
Roman xsymbionts
Trainee Partner
Thank you very much. Corrected the mistake. The test works correctly. But in amoCRM the call record is not saved. Nothing happens in amoCRM. What else is to be done?
In first place, please note that only calls from or to external numbers are logged in the CRM. So please ensure that you're dealing with an external call, because if you test calls between extensions, these will not be registered.
If the calls are not logged anyway, you should enable verbose logs from the 3CX Console > Dashboard > Activity Log > Settings. Then make a test call, and check the 3cxSystemService.log file, which contains the interactions between 3CX and the CRM.
Calls are logged as notes for the Contact or Company. If this is not happening, you should enable verbose logs from the 3CX Console > Dashboard > Activity Log > Settings. Then make a test call, and check the 3cxSystemService.log file, which contains the interactions between 3CX and the CRM.
Please note that the call recording is not sent to the CRM, only a note is added containing the information of the call (date, time, origin, agent that received the call, status, duration).
lastshadow
