Integration with DesktopAPP issue with Supervised transfer
Gbot@Okam
Gold Partner
Dear community,
We experience kinda issue using the integration with Desktop APP.
It works as expected when the extension received an external call on the DDI (%CallerNumber% is the external number)
This is more tricky when the call is transfered from another extension using supervised transfer, the %CallerNumber% is the internal number and never the originated external number.
How can we manage to get the originate external number in this scenario ?
Thnaks a lot for your help, i hope i was clear !
There is no way. Why not use the CRM integration if you just need a URL with the caller number?
Hi !
And using the CRM Integration, is the url containing the external number pushed to the desktop app in the scenario of supervised transfer ?
Thanks for your precious help !
Hi !
Yes
Will try and let you know if this can do the trick ;)
Thanks again !
Robert Lee
