Internal 3CX Server without Access from Internet
DolbySR05
Hi there!
I was wondering whether it is possible to run a 3CX server in an "Intranet-Environment". The server would get an internal IP, an internal FQDN which can be resolved throughout the entire company, can get an internal valid certificate (so self-sign certificates), has access to the internet using HTTP/S but won't be reachable from the internet (security issues). Does this pose a threat to licensing or updates?
Regards
Patrick
Hi Patrick,
The system needs to communicate with the activation server otherwise you will not be able to activate or maintain the activation.
Hi John
The system would be free to communicate with the internet and therefore an activation server. There won't be any NAT rules installed to allow a direct access from the internet to the PBX however. Is that an issue?
Regards
Patrick
If the updates and activation servers are reachable then you should be ok, if you are only blocking incoming connections.
It's still a good idea to run a test deployment first in the intended environment and use it as a proof of concept to ensure you will not have issues.
I imagine you will have open routes to your trunk provider (or a dedicated SIP connection directly with them) and that you will have some way to remotely reach the server via a VPN in order to manage it. Just some things to consider..
Hi John
Regards
Patrick
How would you bring in SIP? You could use a T1/SIP converter I suppose and program 3CX manually? I have debated doing that in some of our HA enviornments to have a T1 for backup, never tried it though.
@DolbySR05
Just to make your life easier I would recommend getting a 3CX FQDN and then just adding that zone/record to your internal DNS for internal resolution. Less management needed.
supuni_rathnayake
