IP Blocked but blacklist is empty and my IP is whitelisted
cwatson
I have been having an ongoing issue with IP blacklisting/whitelisting.
Normally after an update, my office and any at-home offices using the 3cx mac/windows app all get blacklisted.
However, the blacklist is always empty and all my office IP addresses are static and have been whitelisted.
I am running 3cx on the Google Compute Engine cloud. I can connect to a different IP over VPN and get into the management console and indeed verify there are no IPs blacklisted.
Any ideas?
10608
10609
Is this v16? If so, are you using the 3CX global blacklist? The activity log will tell you if you are blacklisted because of the global blacklist.
Yes, version 16.0.0.1581. I am using the global blacklist. I have tried toggling it off, but my local office IP is still blacklisted somehow.
I do not see any information in the activity log about the blacklist.
Hello @cwatson
Can you send me a p.m. with the IPs that get blacklisted so we can further investigate the issue?
hughesdouglas
