is it possible to create caller ID using Prefix?
amannick
Gold Partner
is it possible to create caller ID using Prefix? Pleas help
Regarding your question, can you be a little more specific on what you require, please?
I have a client who has number for each state in USA and they want to select use dedicated caller id for each state. So I am trying to find a way if I can create a caller ID rule by pushing through prefixes for example if I dial 44 - 646-868- then it should dial New York number
this clearly means I have to create multiple sip trunk for each number.....
It can be done with one provider! As long as the provider supports calls from different caller IDs.
Hello Charles
Please help me with process
Did you go through the guides and training that @ClsVip sent to you? It’s pretty straight forward.
Jake R
