Is lightsail install forced to be V20?
AWS2P
I'm just using lightsail this afternoon to add a new pbx and wanted to install it in V18, but for lightsail only it's V20 forced choice and it's impossible to choose V18 on most of others hoster available in pbxexpress it's possible to get V18 .
Is that by design or is there a way to install V18?
Thanks for help.
This is only available to deploy in version 20 with AWS Lightsail.
is there a workaround to get a V18 for now?
All the existing on AWS lightsail are always V18
Strange to be install forced on RC2 V20 instead of stable V18
This is also mentioned in our blog post here.
Yes thanks, few months ago Nick Galea gave us a manual way available from a google doc (which is no more online) and it was working fine. just wanted to try an install using this process but I have not saved the guide so my asking.
Manual installation is no longer available as you can deploy from the 3CX Portal to V20 only.
Thanks, have a nice day
You are welcome ;)
Reactions: Charles_3CX
arming
