Is my IP blacklisted?
robroye
SMB User
Here is the result of my chat with the 3CX AI:
  • Symptom: Web Client access to redacted.3cx.cloud is refused on home and work WiFi, but works on cellular.
  • Environment: SMB Free, 4 simultaneous calls, hosted by 3CX.
  • DNS result: IPv4 xxx.xx.48.125.14, no IPv6 result.
  • Test result: curl -4 -v --connect-timeout 10 https://redacted.3cx.cloud/ returns connect... port 443... Connection refused after 69 ms.
  • Still unknown: whether the refusal is caused by hosted-side filtering, the instance access path, or an upstream route shared by the affected networks.
I can connect to my instance from cellular, but not from home or from work.
Have you tried connecting any phones? You need to fix the root cause first; then the block will be lifted after 24 hours.
I was able to get my phone connected via the app. I am still unable to connect when on my network or my work network.
StevenWillems
